Technical  Low oil pressure
Stealthspocker
Stoke on trent
Hi all,
I'm new here looking for some help with a 2011 qubo 1.3 multijet. Had it about 12 months and in that time serviced it and had the timing chain done. It has been using oil for a while now that I believe could be from the turbo showing signs of wear and I have been topping the oil up regularly. A few days ago I had low oil pressure flash up intermittently but the oil level is fine. Can anyone please tell me where the oil pressure sensor is located as I am struggling to find it?
This weekend I'm going to be changing oil + filter and want to do pressure sensor at the same time.
Scott
Hi all,
I'm new here looking for some help with a 2011 qubo 1.3 multijet. Can anyone please tell me where the oil pressure sensor is located as I am struggling to find it?
Scott
The oil pressure sensor it located nearby the oil filter. (Under the oil filter to be more precise.)
Hi all,
Scott
Did you solve the problem with the oil pressure yet?
Low oil pressure may occur when you have a bad oil sensor or sometimes when the oil pump is broken. On the first case the problem is very simple, you must change the oil pressure sensor With the second problem it's very tricky. Be very careful when the message " Insufficient Oil pressure" appears. Stop the engine and check the cause. Toll the car on a specialized car shop at once. If your are driving even 100 m the engine can be ruined.
