General lost my keys
gussy
hi there ive lost my keys for my car i need to know what the price of a new key is an if any one has contact detiles for a new key thanks cars a punto 1.8 hgt w reg an no red key card :(
You can get a replacement key made by either getting the keycard from fiat and a autolocksmith should be able to cut the key from this else you could have the lock decoded by a tool or by opening a lock and cutting from the pins in the lock, else its a fiat job.
Once you've got a key cut you'd still need it programming.
If you go to fiat they'll do it all but will cost £££££
You could buy a replacement ecu, fusebox and lockset from ebay, which would be the cheapest option (make sure theres 2 keys) although you will need to remove the ignition lock for this which wont be too easy without the proper key. So you'd have to find a way to remove without a key or get a key made up just to remove the lock.
There will be no red key, since it is a mk2, and CODE cards were removed by Fiat UK for some reason, so you have to go to Fiat with your chassis number to order a new key.
do you know the price??
probably cost a couple hundred at least for 2 keys cut and programmed
probably 70-100 for ecu + lockset but will need to remove the ignition lock somehow
