Technical Looking for 2016 multijet 130 2.3 full engine torque specs
TonykR
Feilding
Hie there im new here and im doing a rebuild on a 2016 130 multijet 2.3 and i need the complete torque specs if anyone has them please:)
Hi Tony,
Welcome to the forum. I am not sure what you mean by "complete torque specs", If you are looking for details of the torque curve, you may be disappointed. The 130 version of early x250 2.3 multijet was quoted as having a maximum torque of 320Nm at 2000rpm. Hope that this helps.
All I have is from a 2012 AutoData Manual, so I don't know if your engine number matches or what other differences and sorry for photo quality, old and shakey camera man. If it looks relevant let me know and I will try and take a better photo in daylight.:)
Hi Tony,
The required data wiil be in eLearn for the x250. I have eLearn for the x244, which includes the earlier 2.3multijet, basically the same engine. On a quick check there appears to be 17 pages of torque settings, but this included fuel tank, methane cannisters, and exhaust system, so perhaps only 14 pages.
Thanks for the attempt Mike and yes if you can send a clearer photo i will compare with the bits and pieces im getting from the net cheers
Hi Tony,
Hey communicator i believe it will be similar can you send what you can so i can do a comparison, TIA🙂
This is about the best I can do sorry.
I note there are some special notes against some items 100 (89 in column)81 (in column 104)57(in column122/23/2426)120(incolumn127)103(in column130)plus at bottom of page is the head torque sequence which appears to be normal.
