Light help please :(
F
Fergie
obviously since everyfin was goin smoothly wif the car sumfin bad had 2 happen, get in my car at night, stik on my lights,everyfins fine,later on that evening the old bill stop me and tell me i have a light out at the front, i fot "no bother" go bak home and change the bulb,on the way home my front indicator (same side as headlight) goes out, so bottom line is i have no left headlight,sidelight or indicator the bulb had blown but wen i changed it still no luck,the white connector looks burnt aswell,brown round the edges,i am no good wif electrics,can any1 help?? dont wana hav 2 ring up an auto electrician cheers for readin
Fergie
p.s got the windows tinted yesterday,limo black rear 3 windows,50% front
i would check fuses and earths, if you have a power meter work round the car until you find the problem
fergie. i've got a meter that'll tell you if powers getting to it. same one that diagnosed that you amp was working, when something else wasn't lol.
gimme a shout if you need
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Owner of the Bravo 1.8
Member Page
cheers buzz,yea ive checked all the fuses they r all fine,wen can u squeeze me in m8,ur a busy guy
i know, its all this work stuff!
i'll check my shifts and txt u
Member Page
there is an earth cable kicking about the engine bay rite beside the lights,this cud be the culprit eh? i dont see wher it used 2 be connected 2 tho 2 save me drillin another hole? shud the lights cum bak on if i just hold the earth against the car chassis to see if that is wot the problem is? or does it hav 2 be connected properly? cheers guys
The earth wires are black, if you have found such a wire put it anywhere on the chassis or the engine block - if the lights go on, you have found the problem.
BTW the rear lights have there own earth, so they should work I think.
Members Site - - - - - - - My Site
everyfin is fine at the rear apart from the left indicator goin rapid but thats bcuz the front ones not workin rite? i tried just holdin the earth against the chassis 2 see if anyfin happened but nuffin,il have 2 connect it anyhow but im not sure if that will be problem solved, btw my washer jets hav also stopped workin front and bak,fink this problem mite be linked 2 the lights sumhow?
noooo!, typical! - just wot buzz has bin postin about,but my windows wipers are fine and one side of my lights/indicators are ok,or does this make no difference?
Try feading a new earth to the head light and check if there is current on the connectors. BTW - this may sound stupid, but change the fuses with new ones (both of them) and press the connectors on the back of the fuse panel a bit.
G
582
garaint
G
J
1
776
Dark Lurker
B
2
540
Tommy K
T
