Light Circuit
Light Circuit
T
topmandan
Any1 know which cables are the sidelights and how i wire my fog lights to that circuit.
foglights
Don't tell me you are another of these idiots who insist on breaking the law by driving with the foglights on in any weather conditions?
re sidelights
You could find the correct cable at the side light itself and use scotchlocks to connect to foglights. it would be advisable to fit in-line fuses as well
i got a little blue connector ting its like a clip with a metal piece in miidle
fogs
yeah, thats the one, find the live lead, (use a meter or a 12v bulb)and joine the cables using the connectors. bear in mind other components may run offthe same circuit so to protect against overloading fit a fuse as well. you can push a safety pin through the cable to find the livethen connect bulb (or meter) through to anearth point
fogs
according to haynes the light blue wire is for the indicators. The left hand wire is coloured gr/b. the r/h lighte is y/r. It also shows that the fog lamps should go through a relay, I suppose because of the amperage. Fitting the foglamps without a relay could blow your fuses
J
1
775
Dark Lurker
5
888
Darren
J
732
J
S
2
594
Dark Lurker
