Technical  lhd engine into rhd multi
jetlag
Hhi as per the title really,
Have been offered an engine very cheap but it's out of a Lithuanian car, will it drop in easy enough???? Mine is an 03 bog standard jtd and the donor car is also a jtd but the year is unknown.
Any help much appreciated, thanks
You might need the conversion kit, also might need to use the LHD gearbox as well.
Not sure on the durability of a LHD over a RHD though.
Yeah was planning too as it comes with all ancilliries included, what's Tue conversion kit?
The clutch operation will br totally wrong as a LHD uses cable and fork operated clutch...so you will probably have to remove the gearbox as mentioned
