500L  LF bolt pattern info please
kellyleedupon
would like to know if a maza 2 rim and 185/55R15 are the same bolt pattern as my 2012 fiat 500 lounge as I need winter tires soon lol. only drove my fiat in the summer so far and I am use to big trucks so should be interesting. If someone could please let me know if the bolt pattern is the same.
Thanks,
According to what I found, they probably won't fit. Mazda's look like they use a fitment of 4x100/4x108 (depending on what year) whereas the 500s, use a PCD of 4x98. You'd need adapters or PCD-correction bolts I'd think.
In fact i think even the offset could be off by 10mm, and the bore looks to be wrong also. Not sure you could get them to fit at all!
what is the bolt pattern as I am told different ones it has four lug nuts on it?
Yeah, that's the PCD.
So basically, on the 500, the two holes on the wheels opposite each other are 98mm apart, hence the 4x98 (number x distance). On the Mazda, from what I can see, they're either 100mm apart (4x100) or 108mm(4x108) - so 1cm difference for the latter. What year/model 2 is your Mazda?
If you've got the alloy wheels off already, they should have a number stamped, so "4x???" on the inside of the rim, if not, just knowing the year and whether its a hatchback/saloon should suffice.
Hi, just noticed you are in Canada:)
the mazda 2 in europe is AKA the Ford Fiesta
the FIAT 500 2 door = Ford Ka ( wheels are 4 x 98 PCD)
the NA spec 2 door 500's are NOT the same build as the Europe models..
I have no clue about the 500L ( popemobile) MJG; Tata4Now
I hope that is a little clearer, :)
Charlie - Oxford UK
