General  LEDS behind the heating element
Clock illuminates whenever the ignition is on..low backlight when sidelights go on and full lit when lights are off (daytime).
first remove central cosnsole where gear knob is. then pull out heating switches (behind middle one is bolt), remove radio there are also some 2-3 bolts. about bulbs... i think they are same as for speedometer...
T5 Bulbs (you can use led one)
I'm now aware of this guide for the LED : http://www.fiatbarchetta.com/btech/clkbulb.html
but is there a guide for any of the others??
Partnumbers for the bulbs would be helpful too?
Sorry to be a pain!
Just take a bulb out, nip in to a motor factors and pair it up with another.
As for guides, no one has made one for replacing these bulbs, maybe you could make one as you replace the bulbs?
and be carefully when removing those bulbs, holders likes to crack. maybe you will need pincette (tweezers) to take them out.
