jungle skunk
1.6 1999 weekend (no sunroof). Problem: rain water in foot wells. Which well depends in which way the car is tilting. I have been tilting to the passengers side and collecting the water. I have traced the waters path back to the holes on either side of the dash area. Holes can be seen if you pull off trim on the windscreen pillers or get your head in the foot well and look up. The holes carry the aerial cable (passengers side) and numerous coloured cables (drivers side).
What I haven't worked out is how the water is getting inside the car!
I have gone through various suggestions as found on the many posts in this forum on the subject.
Aerial - removed light etc didn't seem to be leaking but added gasket to inside anyway (MW reception has improved - can listen to footie!) Did notice that underside of roof was wet, water hanging (condensation?) Removed rear light also hanging water there. don't think it had been dripping as back of roof covering not wet.
Cleaned out drainage holes under bonnet - flowing freely now but leak continues
Windscreen - I removed much of the external plastic (around the wipers) to get a look at the bottom of windscreen. Couldn't really see much because of position. Rubber seal at base a screen loose easily removed. Is this right? Couldn't see what it is supposed to seal? Is this leaking? Has my windscreen be replaced? Name model? at bottom corner is "Guardian 43R000305" does this match any one else's?
Any input would be great help.
I dont really know what to do next.How easy is it to remove dash so i could see the water coming in?
