Technical leaking gearbox, from drive shaft
west yorkshire
Hi all, back from hols today and checked my onyx over....only to find a pool of gearbox oil under the off side shaft where it joins the gearbox, i searched the forum but could only find that using a sealant and refit the plate with the 3 bolts...
what sealant do i use, i suppose i have to drain the box again, cant remember if there is a gasket or rubber o ring that seals it or not.....darn blast these teathing troubles...LOL
cheers all
kevin
PS, was gonna have a quick blast n all..
I have drive shaft boots and bearings/seals, they are genuine Fiat, later type.
Here's some pics. for you to check you have the same.......
Let me know if you want them. I also have new lower ball joints/hub carriers if you haven't yet sorted one.
Thanks for the picks but that boot does not look like the one i need, it looks like an outer boot not an inner???
well i replaced the hub carrier last night and removed the off side shaft to check the boot, looked ok so i just cleaned it up, cleaned the box and refitted making sure the bolts where well tight, filled back upp with oil and no leaks this morning so will c how it goes this week.
cheers
kevin
Ah I thought that might be the case which is why I posted the pics. I would think yours is the earlier design that was used on the Mk1, not sure when they changed.
Sounds like you're sorted now anyway. (y)
