£500 budget for desktop, for HD editing and web use.
Derby
Hi as the title says.
Budget £500 for desktop pc and wireless keyboard with in built mouse.
no need for monitor.
Main uses editing footage from my HD camera (sanyo xacti hd2000)
Also internet usage.
Any reccomendations?
aldi
AMD Athlon™ II X4 620 quad core processor 2.60GHz, 2MB L2 Cache
ATI Radeon™ HD 4200 graphics
3GB (3,072MB) DDR3 SDRAM
Multiformat DVD/CD burner1 supports all the usual DVD/CD standards, including dual layer DVD-R and DVD+R
Wireless LAN IEEE 802.11n-standard technology with up to 300Mbit/s., 802.11b/g compatible2
1TB (1,000GB) hard disk for more than 200,000 songs or photos3
Network controller Ethernet LAN (10/100/1,000MBit/s.)
Integrated flash memory card reader, reads and writes all current flash memory cards4
eSATA connection for connecting external SATA devices
8 channel high definition audio5
Connections:
Front: 2x USB 2.0, 1x Microphone, 1x Headphone, 1x eSATA
Rear: 2x PS/2, 4x USB 2.0, 1x FireWire, 1x LAN (RJ-45),
1x Front line out, 1x Back surround line out, 1x Centre/subwoofer line out,
1x Side surround line out, 1x Line in, 1 x SPDIF optical out, 1x VGA, 1x HDMI
Comprehensive software package with original Windows® 7 Home Premium (OEM versions)
…and much more
AMD, the AMD arrow logo, ATI, the ATI logo, AMD Cool’n’Quiet, AMD Opteron, AMD Phenom, AMD OverDrive, HyperTransport, Radeon, The Ultimate Visual Experience, and combinations thereof are trademarks of Advanced Micro Devices, Inc. in the United States and/or other jurisdictions. Other names used in this presentation are for identification purposes only and may be trademarks of their respective owners.
£430
amd 2.6 quad core
3gb ddr3 ram
dvd burner
1tb burner
hdmi (dont be too wow'd by it)
card reader
external sata connection
looks good on paper but depends on the mother board fsb and such, also im not a fan of amd and to be honest seems expensive
bottom one
http://www.cclonline.com/systems/?pro
or on simular spec to saves
Home > My Basket
My Current Basket
ProductsQuantity StockPrice
ex / inc VATLine Total
ex / inc VATMicrosoft Windows 7 Home Premium 64bit OEM
Microsoft's New Operating System
Faster and More Reliable
New Interface / New Features
64bit OEM Package
Code# SFT0121 Mnfr# GFC-00599
104 in stock now.​
£67.11
£78.85 £67.11
£78.85 Gold-Level System Assembly
Let us build your system for you!
Full Hardware Assembly &
All Software Installed & Configured
Code# ASSEMBLYGW Mnfr# N/A
Available to order.​
£50.00
£58.75 £50.00
£58.75 Creative X-Fi Xtreme Audio OEM
7.1 Channels
Award Winning X-Fi Technology
Enhanced MP3 playback
Code# SND1031 Mnfr# 30SB079200000
In Stock Now.​
£28.74
£33.77 £28.74
£33.77 Zotac GeForce GT 220 1GB
Core Clock: 625MHz
Shader Clock: 1360MHz
Memory Clock: 1600MHz
Stream Processors: 48
Code# VGA1208 Mnfr# ZT-20203-10L
In Stock Now.​
£49.12
£57.72 £49.12
£57.72 CiT 1011 Midi Case
Front USB / Audio
with 500W PSU
Code# CAS1230 Mnfr# 1011B
In Stock Now.​
£18.40
£21.62 £18.40
£21.62 CCL Excel Allure Motherboard Bundle
CPU: AMD Phenom II X6 1055T 2.8GHz
RAM: 4GB of 1333MHz DDR3 Memory
MBD: mATX Motherboard with VGA and 5.1 Sound
Pre-Assembled & Tested
3 Year Warranty
Code# MBB-AMD-X6 Mnfr#
In Stock Now.​
£221.28
£260.00 £221.28
£260.00 1TB Hitachi Deskstar 7K1000.C 3.5" Hard Disk Drive
7200rpm SATA 32MB (Internal)
Code# HDD0947_DOTD Mnfr# HDS721010CLA332
In Stock Now.​
£37.44
£43.99 £37.44
£43.99 Basket Total: £472.09
£554.71
note the price can be cut by using lesser parts and shopping around, the parts may not even work together
this would arrive pre built hint the extra 75 quid
Yeh thats fine but its knowing what to get.
Getting the best of everything wouldnt be rite for my needs, and knowing what to get is a mine field.
Is £500 your top budget?
I can take a look at speccing one up, but if you haven't done it before...
Maybe go for an Intel i5. I am not a fan of AMD in anycase.
For HD video editing stay away from AMD. Ideal solution would be a Intel i5 and preferably a ATI Radeon due to the fact you can use an "Avivo" compatible video rendering codec/program and literally half the amount of time it takes to encode video as it will utilise your graphics cards GPU as extra processing power.
Oops, already over budget :eek:
Plus I haven't budgeted for the wireless keyboard with built-in mouse, oops.
Certain components can be tweaked though. However, I am not a fan of cheap cases - my current case cost over £100 alone!
It only took me 10 minutes to do that initial spec, but a good start point - will need reviewing - plus I only looked at one supplier.
Cheers for your attempt a bit over budget though, i thought £500 was a good sum for a pc to handle editing HD.
Probably, but I tend to go over the top slightly. You really do need an i5 in my opinion.
We can come down on the case and the PSU though - £30 is a bit OTT for you, plus the mobo is only mATX. We could also look at a lower specced ATI card.
As for OS - that is up to you. You could go non-legit and save £70 or so - but personally I like a valid key for my OS :)
Dont you need at least 8gig RAM to render HD video in a reasonable time or can you change the 2x2gigs for 2x4 gig?
Also isnt it all about i7 now?
He is on a £500 budget - i7 means a whole different motherboard system, at more expense. Also, did you not read the bit about 'Avivo'...
And yes, he can put whatever memory he likes in - at a cost.
I thought you only did Macs? :p
Yeah but the Graphics is normally what 1gig of which a fair whack would be used for well graphics. But yeah i really dont know much at all. Just that to render properly takes a fair bit of memory. There must be a reason why power macs are mainly being used Video editors and less for Graphics these days.
Oh and macs are now Intel based. (unfortunately)
