Technical  Knocking from back end
mickle141
Morning - getting some knocking from underneath at the back when I go over a sharpish bump or slight pot hole. Ive only just bought it but noticed the bump stops or spring assisters (whatever they are) above the rear leaf springs are pretty much non existant. Will that be causing the knocking?
Is it empty ? if so it looks low anyhow the back of both ours were low after about 12 months & it ate those rubbers we fitted secondary coil spring kits to help then new rubber things. (easy to change though same as the secondary coil spring mod)
Fiat really should have addressed that problem still the newer model has coils which I hear give shocker problems.
Yeah nothing in the back. Except seats of course.
