Technical  kill switch on a 2000 sei sporting SPI
meshgrid
hi,
i want to install a kill switch on my seicento. it's an SPI sporting, 2000.
i'm using this switch: https://www.ebay.com/p/22017017042
as you can see, the switch has 3 pairs of poles: 2 main poles (the big ones, they go between the battery + terminal and everything else), 2 poles that are normally open (they close when the switch is turned off, any residual voltage/current needs to go here, through a resistor towards earth) and finally, 2 poles that are normally closed (they should cut the spark so the engine would turn off).
i'm wondering where i should connect the 3rd pair. the goal is for the engine to turn off as soon as possible. fuel pump comes to mind, but it isn't an ideal choice (since the engine will continue running until there's no more fuel in the pipes).
i thought about cutting the supply to the crank sensor, but from what i read, this signal is kind of sensitive (normally these wires have shielding) and adding a meter of (unshielded) wire could hurt.
next idea is using the wires in the ignition barrel, but i haven't had any luck here so far... according to the diagrams i find online, the big brown wire in the smaller of the two connectors should do the trick, but my master switch is somehow bypassed when the key is in the on position.
so, now i'm looking at the fusebox behind the battery; there are two fuses there that could help: "EFI" and "IGN". will the EFI fuse eliminate spark?
do you guys have any other ideas?
thanks!
A quick update, in case someone runs into a similar problem: i ended up using the EFI fuse. From what i read, this stops power to the ignition coil. When this fuse is pulled, car turns off immediately.
not sure what you mean exactly from that terminology, but i assume its the fuse for the engine ecu and thus all the sensors on the engine..
Another good place i think would be the fused line to the fuel pump relay, oftentimes called the twin relay in fiat circles i find.. this relay powers the pump but it also is the relay that fires the coils, so kill power there you get no fuel and no spark ;)
