key fob cracked. any thing i can do?
jms700
Stirling
fell over the other day and cracked my key with central locking, still works perfectly but theres a big hole in the plastic, wondering if there was any way of getting a new case or something ? or if i just have to live with it ?
thanks
What kind of key is it? One of the newer flip out Fiat ones like these...
...if it is you may be able to get a new housing on eBay or some place similar and transfer the internals across but I'm not totally sure if you can. If you have to get a new one of those from Fiat it costs quite a few £££s.
as said you can just buy a replacement housing and swap all the bits over think the fiat 500 with the cover clips are a bit harder to find at the moment but the one above are pretty easy to find around
thats perfect, thanks, its the old bue keys with out the flip out key. and what would i do about the actuall key that goes into ignition ? will that swap over aswell or would a key cutter do it ?
thanks
thanks
If you've got the red key, you should be able to get a new one made up at Fiat I think. Don't know how much it'd come in at though...
ahh so you have the old blue and red keys not the new shape flip out things shoundt be to hard to get some sort of replacement sorted for it i would assume
