Technical  key code warning light on dash
hansolo2
I have a 2.0 20 valve 1997 it was starting fine but now there is a key code warning light on can anyone help?
The fact is if its anything like most Fiats with the same issue its not recognising the key.This may mean anything from cleaning relay connections under the bonett, checking the ignition antenna and trying a different key or recoding the setup.
