trickydisko
- Joined
- Sep 21, 2005
- Messages
- 20
- Points
- 5
Hello, I have an old 1990 Tipo 1.4 Formula, which is having problems accelerating after it's been rained on. The engine seems to judder (ie. it'll accelerate for a second, then back off for a couple, and repeat) when the accelerator is depressed, this tends to last for about 15-30 minutes of driving before it returns to normal. The problem seems most apparent at medium revs, at low revs it doesn't stall and at high revs the engine seems normal. When juddering, the acceleration follows the engine note, so I don't think anything's slipping.
Can anyone advise me what might be wrong with it, and how expensive it would be to have repaired (I can do a few very basic repairs, but I'm not confident enough to mess around with the engine itself)? The problem is annoying but the car is still driveable, so I'm not inclined to pay for a costly fix.
The general condition of the car is pretty good, it's been well-serviced up until 2 years ago (only oil/filter and brake pads since) and starting in the wet isn't a problem, although the engine tends to be quite lumpy when first started, and will eventually cough its way to a stall if I don't press the accelerator a little.
Thanks in advance for any advice you can give me!
