Technical  jtd schématics
niallof
saint jean de braye (45)
hello
i want put cruise control on my
marea week end jtd 110
does anyone got a schématic of injection module. i think that it's the same than stilo in fiatforum
so it seem possible to install one without bying a after market one.
thank you verey much
hello
Sounds interesting, if you do get it to work make sure you come back here and let us know how to do it. :)
Have a look at these workshop manuals...
http://babarmalik.com/ledmods.htm
ok thanks for the link.
the jtd schematics are
p.632 vol4
p.701 vol4
p.708 vol4
of the workchop manual.
the four points are not connected
on the new bravo The following wires must be connected then fed to the cruise control stalk
M10-A (Engine Node) ------> H7 (Cruise Control Stalk)
1.9 JTD
Pin 53 ------> Pin 4
Pin 55 ------> Pin 1
Pin 56 ------> Pin 5
Pin 57 ------> Pin 6
Then, proceed as with the previous page to get the wire into the car, then hook up the +12V feed etc etc. . .
Just incase you want to use another method for switching (someone on the Italian Stilo forum used a Sony joystick!), here is the wiring information:
Pin 1 = Green = Resume
Pin 2 = Blue = +12V feed
Pin 3 = Not Connected
Pin 4 = Violet = ON/OFF Switch
Pin 5 = Orange/Black = Speed +ve
Pin 6 = Orange/White = Speed -ve
so the question is : do you think that if we put new wire on pin 53 -55-56 and 57 we do made a cruise control ?
thanks
the connector is
attachment.php
and the pin 53-54-55-56-57 are not connected as shown
the new question is : the jtd 110 electronic module is the same on marea jtd 110 and on new stylo jtd? is it the same pinout. If the two part ref are identic, it seem that the cruise control could be install... on, each jtd.
might not be as simple as wiring it up.. usually the software would be different or at least the cruise control would need to be enabled in software.. this would require the FIAT examiner tool.
yes it would. please read the very good "bravo cruise control" post you will see that you don't need any reprogramming.. the only think is : bravo jtd 110 and marea jtd 110 injection module got the same part number? if so, the only think is to connect the four wire and that's it.
I'm back
i do all i describe. good wiring as i say but it doesn't worth. i think i need ecu reprogramming or change ecu for a bravo one. i lost my time and my money but now, we know that it isn't just a wiring issue.:cry:
