Technical Is there an air bleed screw somewhere?
shotaroJPN
JPN
I own a Fiat Ducato Motorhome model 2022.
I need to bleed the cooling system as I have changed the coolant regularly.
I cannot refill the remaining 1 liter or so because the air does not drain out easily, is there an air bleed screw somewhere?
Model
2184cc diesel 118kw engine model 46
Year
2022
Mileage
20000
Hi on our 2017 3.0 X290 there is a black plastic fitting with a bleed screw in the middle of the engine compartment where both the heater hoses both go through the firewall. I would think this would be common system regardless of which engine is fitted.
Yep same on a 2000 , 2.8 tdi . Exact same place . About the middle of the firewall .
