I bought a 2002 1.6 Dynamic last year & have had nothing but trouble.
Problem were/are:
Engine Failure warning
Airbag failure
Rear stop lamp failure.
The lamp is sorted & turned out to be a matter of loose wires & the Airbag is the same (which I understand to be common) so I can live with it until I know of a permanent fix. The real problem is the Engine failure.
So far I have replaced the ECU, the potentiometer & the accelerator, now I am being told it is likely that one of the valves has gone.
It has always felt sluggish even when the warning light isn't on & before the ECU was replaced the car would lose power intermittently when the light was on.
They have now discovered that one of the cylinders isn't sparking & that disconnecting one of the coils/sparks makes no difference. Both spark & coil were replaced after that to no effect. Clearly the car has been running on 3 cylinders only.
Am now being told that the they need to get the head off & look inside & that although the valve isn't expensive, as they'll need to skim the engine etc that the cost will probably be circa £800.
My question is , after spending £700 already on a car which only cost £3600 is it worth it & is it likely to be resolved?
If anyone has any answers or common experiences please post back.
Airbag failure
