Technical is it possible to change manual mirrors to electric on my punto mk1 sporting??
charlene homer
paignton
ive found some electric mirrors that i would love to get but my punto has manual mirrors mine is the punto sporting mk1 it has electric windows if that helps lol just wondering if any 1 has converted theres to electric if so where do you get the switch from and where does it go?? and how do i connect if there no connector there??? please help if you can thanks x :idea:
would be a nice thing to have i think x but if its to much messing aroung i dont think ill bother but ill keep lookin and check out how much it will cost first. which car do i get the door cards model ect???
u need the wiring loom upgrade to do it not a door card upgrade although u can upgrade to higher model quite easily with the punto check in a scrappies....
which model yr punto mk1 will have this loom as will go look if some1 can help me buy tellin me what i need to look for x as aint got a clue please help if ya can x x
I did this mod on my 75 ELX ages ago. It all started when I took the drivers door card off and spotted the spare connectors on the loom that needed to go to to switch and to the mirror motors. I then checked the wire colours were correct to the Haynes manual. I replaced the two button electric window switch panel to one from a GT and connected up that extra wire to the mirror pad switch. Replaced the tatty old manual wing mirrors with new painted electric ones and connected up. No extra wiring was required as all the fuses/relays present in my case. It even defrosts the mirrors when the rear defrost button is pressed!
Your car may be different, firstly see if theres a couple of spare leads that are not attached in the drivers door before continuing to source parts!
