Hello all and Happy New Year, hope your Stilos behave well!
In my previous cars I've always changed coolant with every second oil change. I do this not for the antifreeze properties (we seldom get temperatures below 0-degrees C in NZ) but rather for the anti-corrosion protection which is essential in modern engines.
Usually I find systems in a state of total neglect, but in my Stilo it still looks fine as you'd expect. But I note the service schedule does not call for changing the coolant, ever. This seems strange given that Paraflu 11 has been around for ever (it is not one of the new 5-year longlife OAT coolants) and so after two or three years, I'd expect its time to be up. What do you think?
Of course there is also the practical issue (I haven't managed to catch sight of the bottom radiator hose), so I'm thinking of syphoning-out the expansion tank, refilling with fresh mixture, and doing this a few times over the course of a month or two. Do you think this is acceptable? I plan to use a pre-mixed coolant (made with distilled water), since Paraflu 11 is not readily available.
Cheers for any comments on this...
-Alex
-Alex
