No luck, just wasted an hour eventually pulled the earth lead off one half of the horn push and when you connect up the horn away it goes. It does seem to be further down the column. I got some weird results with the meter and this explains it.
This is scary , as it's earth lead off, will the radio and ECU ever work again, and fiddling around with the airbag clockspring. I'm not sure I want to bother actaully.
