C Carts69 New member Joined Sep 16, 2017 Messages 8 Points 4 Nov 3, 2017 #1 Can anyone shed some light on why the indicators on my scudo van are fine & then start flashing iractic, would this be a switch problem or relay?
J jimboy Patron member Joined Aug 2, 2006 Messages 3,891 Points 852 Location highlands Nov 3, 2017 #2 Usually when this happens it tends to be the relay.
OP OP C Carts69 New member Joined Sep 16, 2017 Messages 8 Points 4 Nov 3, 2017 #3 Thanks jimboy, do you know where I can locate the relay & where best to purchase a new one?
J jimboy Patron member Joined Aug 2, 2006 Messages 3,891 Points 852 Location highlands Nov 3, 2017 #4 By all accounts it's tricky & located at bottom of steering column. A wee look to the tinternet will reveal all.....
OP OP C Carts69 New member Joined Sep 16, 2017 Messages 8 Points 4 Nov 3, 2017 #5 Thanks, found the info now, any chance you could answer my other question on the forum, regarding how to drain the cooling system, can’t seem to see how the bottom hose detaches from the radiator?
Z Zog Established member Joined Sep 3, 2010 Messages 478 Points 213 Nov 4, 2017 #6 As you've found the info, perhaps you will post it here?
OP OP C Carts69 New member Joined Sep 16, 2017 Messages 8 Points 4 Nov 7, 2017 #7 I found the info within this forum
