Some more updates on our project...as you can see from the help we’ve been asking for (thanks again) we are a little behind on the thread, but we’ve been making progress on some small and big jobs.
The hand controls were something I wanted to keep, rather than go for a solenoid type starter.
The rubber tips to the controls were in bad shape, so I cleaned them up with some wet and dry paper.
I had to replace the large roll pin in the centre with a bolt because it was bent. I ground the bolt head down flat so it would clear the inside of the plastic centre console, and painted it satin black.
All fitted with refurbished rubber tips.
Next it was time to tackle the "air conditioning".
The fit of these original parts to the body wasn’t great, and I didn’t want fumes from the petrol tank areas making their way into the cabin, so I made some fabric gaskets to try and limit this.
Fitted and now flush to the body.
We refurbished these parts some time ago and re-plated the spring clips that hold the valve into position/shape, so hopefully these will last a lifetime.
Fitting the tubes was a total pain.
Thankfully all done.
We also finished up the wiring. We bought a “high quality” loom and I’m pleased to say it lived up to the name, everything was labelled correctly and was the correct length (other then some wires we had to shorten/lengthen due to fitting a 126 engine/box, and having to make up some earth wires for the front lights) We also took the time to cover all of the metal tabs in heatshrink to stop any abrasion issues.
Once the vents and wiring were in it was time to put in the fuel tank. I started by using a small quantity of contact adhesive to hold the cork strips in place.
I did the same to the underside of the tank.
For the run of fuel line from the tank, through the centre tunnel and out the rear bulkhead, I got some over-braided ethanol-resistant hose, so it would be more resistant to abrasion in unseen areas of the car.
I used a flame to seal the braid.
And I applied some heat shrink to keep things neat.
And fitted to the tank.
Sender wired in.
Finished!
I also had one remaining rear axle to set to the appropriate torque after having to wait for a new nut due to stripping the threads from the last one. What a pain these were! :bang:
Now it was finally time to put the new engine and gearbox in. After struggling with moving the engine and gearbox when we removed the original, we decided to keep the dolly we used for the bodyshell with the plan of modifying it to fit the new engine and gearbox.
The dolly was duly made up using parts of the old one and part of the crate the engine was delivered in. What you can’t see is I made it with a kind of “puck” underneath designed to fit the head of the jack right at the CofG of the engine/gearbox combo, so it would be easy to lift the short distance needed to get it in, I didn't want to drop my new engine!
Rear engine mount on. I had to steal some studs from the old engine to fit this properly.
And just like that, it’s in...it is only four bolts I suppose. We did have a bit of a faff getting the engine mount spring in, but once we had compressed it, it went in fine.
Once everything was torqued up I used the paint pen to mark the bolts.
Now it was time to connect up the gear selector, heat pipe, starter cable, battery cable, etc that are hidden underneath.
One hungry Fiat.
Driveshafts went in next.
Torque set and good to go.
All connected.
Next on the list was to get the engine ready to run. We purchased the engine some time ago and it had sat in my garage ever since. I did occasionally turn it over by hand, but I was worried that all the oil may have drained from the head etc. during storage. Following some advice on here (thanks) I removed the rocker cover and put some oil on the moving parts.
Before:
After:
I also removed the spark plugs and dropped a few drops of oil down each hole to lube the bores, and cranked the engine by hand for a few revolutions.
We then dry cranked the engine to see if the oil pressure warning light would go out, but it would not...after much worrying and some encouragement on here (and after a bit of faffing getting the fuel pump primed) it fired up fine and the oil pressure warning light that had started on during dry cranking went out immediately. Result! :slayer:
The engine would however die without quite a lot of throttle, some adjustments to the idle screw and mixture and now it starts, and runs well cold and hot. (Thanks again to the helpers on here for the advice about setting up the carb etc.)
The next day we decided to make a few changes after the clear fuel hose we had purchased from a well known 500 supplier had essentially melted overnight. It had gone very soft and seemed to be porous, or at least the garage stank of fuel. So with that we went to a local motorsports supplier and bought some new R9 nitrile hose and a brass tee so we could route the return rather than blocking it off at the carb.
I also picked up some DEI exhaust wrap whilst I was there to try and keep temps down in the engine bay and make the life of the coil etc. a little easier. I also decided to repaint the “manifolds” VHT matte black.
Painted.
Wrap on. This wasn’t too difficult but it is fibreglass, so prepare to be itchy for a day afterwards!
Next was something we were dreading...glass. We elected to use the string method, and we also used a heavy duty suction mount to help hold and pull the glass where needed.
Meanwhile my husband polished all the glass after I had cleaned it using a razor blade to get rid of all the old bonded seal/crud.
Side glass in, these were the easiest ones. The seals were dunked in hot water prior to fitting so they were nice and supple, this definitely helped.
Rear window in, this one was a little more difficult.
Front window drains in place.
Draining into the front wings...need to check this is the right spot!
The front screen was a different story, it was a much tighter fit than the others and took 2 tries to get right.
Front bumper went on next, he finally has a face again!
Now the engine bay was complete, the rear lid could go on. This took some tweaking of the mounts and some modification to the lock/seal, but the fit is finally good.
Getting so close now. Hoping to get the doors sorted this week, plus we have the bonnet fit to tweak as it's catching at the front edge. One thing at a time but we are getting there…
More soon!
