K
kenneth
I recently took over the ownership of a 97 Fiat Brava 1.6 ELX. It has clocked 90,000 km. The car runs well except for:
1)A problem with the automatic gearbox
2) Engine seems to hesitate a little when revving from cold start
Auto Gearbox problem
Its gearbox indicator light will flash to indicate a fault when I attempt to drive off after starting the car in the morning ? I will then have to turn off the engine and restart the car, and after a number of attempts, the fault would clear, and I would be able to drive it without any problems. What could be the cause of this ?
I have sent the car to a local Fiat authorised garage, they interrogated the gearbox ECU with the Fiat Examiner which reported:
- A hard" on "lock solenoid open circuit or short circuit to +" failure.
- Soft "incorrect gear lever position" error
My questions (and I hope someone out there can shed some light in this matter):
1) Has anyone out there encountered a similar fault condition before ?
2) How can I physically check the condition of the lock solenoid (the Haynes manual does not come with an electrical diagram for the Aisin gearbox) to confirm the problem ?
3) Is it an easy repair job to access and replace the lock solenoid ?
4) Could the gear lever position sensor be intermittently failing ? How can I confirm this ? Is this a common failing item for a car of this age ?
5) Does the lock solenoid and gear lever position sensor (Aisin gearbox)have common parts with other makes of Japanese cars (Toyota, Nissan, etc.)?
I have the external wiring and connections leading to the gearbox and they seem to be OK.
Engine hesitating problem
Examiner interrogation of engine ECU gave:
- Soft intermittent error for lambda sensor
- Soft engine operating parameters out of range
Any advice or responses is much appreciated and eagerly awaited.
Great forum !!!
Regards,
Kenneth
Malaysian Fiat owner (small Fiat community)
Great forum !!!
Regards,
Kenneth
