Hey Guys
I have a 2007 1.4 tjet 150 67k. Ive had issue with power loss and very recently throttle cut out. I have found a snapped wire in the loom.
Will go through the issues and then the images of the snapped loom.
Ive noticed recently that my car is very sluggish in 1st and 2nd, the point at which i need to change up to keep accelarating is much much sooner its basically tap,change,tap,change to get the car moving.
Once in 3rd it feels better and i took it on the motorway over the weekend and the car still accelerated very well from 70 to 100 in 6th gear.
Yesterday i had the car repeatedly loose all throttle response at 2500 approaching 3000rpm even with the pedal all the way down, if the car was changed down or the throttle released and applied again would make the car act normally. It also did it a few times to and from work today.
I had a look in the engine bay for any loose hoses and noticed a black cylindrical sensor with 3 vacuum lines into the wastegate, intake and (i think) exhaust manifold was just flapping around the engine bay having snapped its mountings. The sensor was resting on the turbo housing. I thought the heat may have cooked the sensor or wasn't doing it any good.
Closer inspection while zip-tieing the sensor back I found the wire to this sensor was snapped and heavily oxidised on both ends. It is snapped right at the plug leaving only 10mm of wire to play with.
I cleaned the wire off with some grit paper and twist-tied the wires back together and then went for a spin.
The car feels alive again and the turbo kicks in nicely making it feel like it's back to normal but the throttle is still cutting out making it lurch forward like gearbox braking whenever the throttle is disabled as mentioned before.
So really i will need a new loom so need an idea on where to source one and i'm also concerned about the throttle still cutting out if i have fixed the boost issue. Maybe the wire is so corroded that the signal is being lost due to my bodged twist tie method? Has the car remapped itself since having to work without the input from the sensor and now needs the ecu resetting?
Car is booked into the mechanic on friday who was originally going to check for clutch slip and also the brake light sensor. I will show him the loom but willIi be able to expect him to repair it by replugging the loom or will he need to go to a wreckers?
see image for broken wire
Any ideas on where to get a new loom if it can't be replugged and how much will it cost, how much would my mechanic expect for doing the work needed?
Thanks for reading and thanks for the replies
EDIT: After Googling, i think this is the wastegate valve or such type. a N75 valve?
