Technical Interior Light
Nello
Established member
Warwickshire
Just noticed the interior light has stopped working? Its the one in the middle of the roof liner that illuminates when the doors open. Thought it was just the bulb but I took the cover off tonight and gave it a quick poke and it did flash on briefly. I'll take a full check in the week but on the odd chance anyone else had an issue with theirs and what was the fix?
Hi Nello
Funnily enough I had this problem, bulb seemed OK, all switches were fine as were all fuses. Tested circuit that was fine too. The problem pointed to the bulb but I didn't have a spare and it looked perfectly intact. (I was 17 miles away from garage / car parts)
The solution was to 'rough up' the connecting ends of the bulb so it made a better connection.
Rough up = scraping both metal ends of the bulb across the pavement.
Refitted and the interior light has worked fine since. (y)
Hi 50p .... :D Sounds like my kind of solution.... I'll give it a go mate cheers.
50p...guess what...........Worked!! lol - seems the Sedici is a proper Fiat after all then.
