General Interior light/switch panel
AaronSablon
Hi all, not sure where this should be posted.
I have a Bravo MK2 T-Jet 150 Sport with Skydome
My internal light/switch panel has been replaced by someone else (previous owner) I’m missing some switches to the amount of wires I have in the car. For the life of me I can’t find the correct part/part numbers. Anyone help at all...?
I have attached a picture.
Aaron
Yeah my Skydome doesn’t open nothing happens when I press the open button, but when I press the close button you can hear the motor clicking.
Hi Aaron, I started having exactly the same issue a couple of weeks ago.
Have you replaced the skydome motor at all?
I'm not sure if it's the interior dash since it used to work fine.
I've called 2 FIAT garage's(/dealers) and they haven't seen the issue before.
I can't seem to find anyone else with the same issue, or my search engine skill suck so I'm curious what you've already tested.
Update:
I went to the garage to find out what the issue was.
Apparently it's the rails that has de-railed from the housing.
It's basically just a rod that goes round in a certain way, if that rod is damaged or has gone out of it's housing it won't turn anymore.
There's no real "easy" fix for it.
Basically you have to remove the head lining from the back, take out the electric motor and possibly take out the whole rails.
If it's a problem with the motor you're "lucky" if it's with the rails, the whole thing has to be replaced and it just takes a lot of manhours to fix it so it can probably cost you up to 700 euro's if not more.
I hope that gave you some information.
If there's any more questions feel free to messag me.
