- Joined
- Apr 6, 2012
- Messages
- 5,066
- Points
- 1,163
Front mount or better cored standard fit?
Front mount...
+ Bigger surface area to allow improved cooling (allegedly).
+ Somewhere better than behind the headlight to put the air filter.
- Distance from the turbo to the inlet increases causing lag.
- Weight.
- Looks naff.
- Cost (no cheap eBay jobbies here)
Standard fitment with a better core.
+ Cheaper (not cheap)
+ No cosmetic alteration required (stealth).
+ Weight.
+ No cutting stuff.
+ Standard distance from turbo to inlet so less lag.
- Behind the radiator so still an inter-heater rather than intercooler.
- Air filter location.
- More difficult to get to if a pipe gets blown off or other issue.
I'm considering these options...
Front mount kit by reputable company.
http://www.ebay.co.uk/itm/Pro-Alloy...A&clk_rvr_id=1041520972793&afsrc=1&rmvSB=true
Standard fit with a decent core Integralle spec'.
http://www.ebay.co.uk/itm/Intercool...5&clk_rvr_id=1041527955495&afsrc=1&rmvSB=true
Thoughts, opinions, ideas and suggestions are as welcome as votes.
Front mount...
- Weight.
- Looks naff.
+ Weight.
+ No cutting stuff.
