Technical Insufficient Engine Oil Pressure Warning
ash007
Trowbridge
I have Fiat Punto 2012 model, since few days whenever I am driving to a location after 10-15 miles my car has a warning beep nd message displays as - "Insufficient Engine Oil Pressure". I keep on driving after that as most of the time it happens on a busy highway/road and nothing after that, then this repeats again after 1-2 weeks and so on. I have already checked my engine oil level and it is fine. Any suggestion to get that fixed in a cheap and effective way please?
First check the electrical connection to the oil pressure sensor on the engine is secure and retest, then you need to replace the oil pressure sensor just to eliminate it. (Not a lot of money usually like a tenner)
(Usually found near the oil filter with a single electrical cable coming off it.)
After that if still faulting you're going to need to check actual oil pressure, but actual oil pressure problems would normally first show fairly consistantly when idling
