Technical Instal xenon headlights on croma without xenon
KUM4o
Hello from Bulgaria. I apologize if there are errors but I use a translator. I have xenon headlights from a facelift before. I want to put them, but my are with a reflector. Those who have xenon would become unmodified or have a difference in connectors?
In theory you need to have the complete headlight units with power packs, plus the automatic leveling system including suspension sensors. and the headlamp washers. I don't think the lights will work properly without the other units especially the auto levelling. You are likely to get failure warnings on the dash.
Robert G8RPI.
Absolutely easy to convert. Add several cables to the original headlamp connector. Two automatic headlamp leveling potentiometers are added. They may not be added, but the leveling will not work. Then, with the fiat scan, the xenon module is activated and everything works without any problem.
