Technical  injector light stays on
chesters83
dose any one have any ideas on why my injector light on my 1.9 jtd stays on its starts fine but the glow plug coil light flashes for about fifteen seconds as well is that normal any info would be very greatful
ECU should have an error logged, you need to get the error code using a scanner which will tell you what the problem is.
Not aware of any way of getting error codes without a scanner.
My 110sx 1.9jtd had the same prob poped to fiat bloke gave some advice to use some diesel redex never seen the light again if you choose to try this let me no how you got on thanks
Mine had same - I have a pet diesel mechanic and he told me it was just condensation and I think he just blasted contacts with electrolube which fixed the problem.
Some untamed mechs will tell you that you'll need new injectors to fix the warning - Before you go that far though, make sure it's not as simple a thing as damp contacts.
