General Injector fault warnings :(
Code Breaker
London
Ducato 3.0 2015 comfortmatic 43k miles, sits happily on idling but when driving I've got errors on injector 1 (P0262) and 3 (P0268), *fuel gauge drops to zero*. I've had injector 4 replaced and this reads 175ohms across pins within 2 seconds, with an ohm meter, however, the on the rest of the 3 injectors, the meter readings climb up slowly. I believe 1,2,3 are faulty but 2 never shows an error.
3.0 Injector clamp Bolts. Does anyone know where to get these for a reasonable price as they're extortionate prices out there.
Thank you, are these stretch type as I've been told thats what i need to replace them with. Also where to source them from please?
Stretch bolts aren't cheap to start with, I'd just bite the bullet with genuine.
How much have to you seen them for ?
How about these> https://www.ebay.co.uk/itm/125110064210
Double check fitment, but when I was searching earlier it looks like 2.3 and 3 are same part
That postage costs bring it to over £20 a bolt
Why would you need stretch bolts. You are only holding an injector down.
Just make sure there is clearance and the thread in the head is very clean. A tube on a vacuum must be used & the use of a scriber or similar to be sure nothing is left in the hole. I put a thin coating of grease around the shank to hopefully make it easier to remove one day down the track.
I agree, but I was only going by what I was told that they have to be stretch bolts, as im working around the vehicle to restore everything i can to original. I'll look at what is available and prepare as I'm awaiting delivery of 3 new injectors.
