General Injector fault warnings :(
Another question is, do you think it a good idea to break the rubber seal around the neck of the injector and flood it with penetrating oil like WD40 in the hope that it gets in-between the injector and wall? I was thinking it can't do any harm if I do this and leave a couple of days. The last injector broke inside the head and the guy drilled it out millimetre by millimetre, so to this logic I suspect rest of the injectors will also protest extraction, hence if I break out or at the least put a hole in the rubber seal and put oil it may help.
