Injector correction limits. Doblo 1.9 multijet
West Wales
I've got an ongoing problem with my 2006 Doblo 1.9 multijet, it's a fault code P1206.
To cut a long story short, I found a Fiat service sheet about this problem ( https://manualzz.com/doc/6412115/operation) and on the list was injectors.
This is what it says:
Injector correction. Check single injector is comprised between -2 and +2 mm3/injet with the engine idling and warm.
Well, I've checked this out with MES and all injectors are within -2 and +2 (max at about +1.5 and -1.5).
On a run I graphed the correction of each injector. Cylinder 2 & 3 were always within the +2 -2 but cylinders 1 and 4 peaked at around +4 -4.
Is this normal?
Any ideas much appreciated.
Ron
There's lots on the internet about injectors but not much about these correction values.
Can any of you knowledgeable folk help me out on this one?
Ron
