Technical Indicators
Stuventus
Morning Everybody,
Having a problem when i indicate left,the arm goes down and the indicator works,but as soon as i brake it stops blinking!!!:mad:
When i turn right everything works perfectly ok!!! (y)
Any suggestions
Dodgy earth on the LHS lights somewhere, sorry I dont know where the earth / grounding points are but find them, disconnect all wires, clean them & the wire connections back to clean metal, re-connect tight & smear with a copper based grease.
Then go over all the bulb / plug - socket connections with some switch cleaner too. (y)
