Lawrence53
I have an intermittent fault with the r/h rear indicator. The bulb is ok, but the yellow light warning comes up on the panel, and I then have no rear indicator r/h side and if you press the brake pedal the mirror indicator lights up. I have checked the earths.. This problem will then disappear after a while and then come back. I suspect it may be a relay but cannot find where it is. This is a 2009 Ducato. Many thanks.
