Hi guys and girls...
So the time has come for imola to become a member of the boosted cento club.. Ive decided to make a new thread to hopefully help others along the way one day and hopefully to reach out to those in the know ( I may need some help
) and also to hopefully get another thread thats easy to find for a p75 mpi based turbo conversion
So this is the plan..
P75 head that will be worked and may have a minor skim
P75 inlet and throttle body bored out to 40mm
P75 '866' camshaft
1242 8v block from a mk2 punto with 1242 16v pistons and rods (to lower the compression ratio)
As yet ive not decided what crankshaft ill be using however itll be either the standard 1242 8v item or the lightened and knife edged 8v one from the wolf direct engine
modified sump with oil return and hopefully an added breather to an oil catch can
Garret gt14559 roller bearing turbo with spi manifold modified with a turbo flange
Mocal oil cooler and thermostatic sandwich plate with braided lines
Unknown front mount intercooler will update (fmic)
Sard fuel pressure regulator (fpr)
Innovate motorsport lc2 wideband controller
Prosport boost, oil pressure and oil temp gauges
This is the initial spec of parts I have and that il shall be collecting over the next week or so, ill also be looking into a turbo timer and either the det3 from ecumaster or megasquirt as engine management, I need to get a 3bar map sensor and work out why and where a fcd gets wired in.. (more research to do)
If anyone can identify things that ill need that isnt listed above then your input would be greatly aprreciated
This will be a slow build and ill update as and when progress happens
Cheers in advance
Lee
P75 '866' camshaft
Cheers in advance
Lee
