the hobbler
Distinguished member
- Joined
- Jul 25, 2012
- Messages
- 4,503
- Points
- 1,133
What model 500 do you have? If it is a 500D, according to my 'Factory' book-of-words, all fuses should be 8 amps. Also, the photo you have shown does not match the wiring diagram you have shown. According to the photo, the 2nd wire down on the right of the fuse box (and it should have an internal connection to the top terminal) should be green (verde), and go to the 'Outer lighting switch'--there is no wire to the top right terminal. Lastly, the bottom right wires should be red (rosso)--1 goes to the positive side of the battery, the other wire goes to terminal 30 on your ignition switch (lock switch in 'Fiat-talk'). The wiring diagram you have shown does not have this battery/fuse-box feed and diagram is possibly for the 500R. I am NOT an electrician, but having just had to sort out the wiring on my 500 after it came back from the body-shop (with, let me add, a great deal of assistance from my son who is far more 'electrical' than I am) I have suffered similar problems!
