Hello fellow forum members and happy new year!
A bit of background on this one: I set off from Paris to Zurich and on to the Austrian and then Swiss alps with my 1988 Panda 4x4 Sisley between Christmas to today. She performed really well despite very cold weather in the first half of the trip. In the last few days however, she has started to stall on idle even when the engine is most definitely warm. The only way to save it is to pull the choke out slightly before coming to a stop or to rev it continuously.
It is not particularly cold now (between 3 and 6 degrees) although I am at 1,800m in altitude, it was also behaving the same way at 1,200m – so my suspicion is that it is not altitude related.
The car seems to run fine while under way.
I have done some research on the forum and compiled a list which I have tried to sort in order of intervention difficulty:
I would be very grateful for your view on the items on this list or if there is anything else that could be an obvious culprit.
Thank you.
| Order | Item | Question |
| 1 | Check distributor cap | What should I check for here exactly? |
| 2 | Idle speed | Increasing the idle speed would probably fix this but would I just be hiding another underlying problem? |
| 3 | Spark plugs | |
| 4 | Ignition timing and the points gap | How? |
| 5 | Fuel pump | |
| 6 | Check that there are no air leaks and air filter is clean | How does one check for leaks? |
| 7 | Vacuum advance unit or a condenser breaking down |
Thank you.
