I have stripped a couple of top ends and have found one cam that measures 9mm lift in and ex.
Where as all the other cams i have measured come out at 8mm lift in and ex,which i think is correct for the mk1 stock cam?
The 9mm cam also dont have Fiat stamped on it like all the 8mm's do.
The 9mm's groove for the distributer looks correct and original so i dont think it a mk2 or punto cam?
Do all orginal Fiat cams have Fiat stamped on them?And do any of you guys know of any cam makers that produce a cam with 9mm in/ex lift?
I cant seem to find any and would like to know what the duration of this cam is.
All i can seem to find on the 9mm cam is a small circle with maybe a C? stamped into it on the middle of the cam?
