Panda (Mk3) Identify Sensors
John Perry
Hi everyone
Can anyone tell me what the two sensors are on the side of the throttle body on fiat panda 1.1 2010 please?
Just discovered a broken orange wire on the sensor on the left of the picture!
Thank you
Hi there
Thanks for info
These have caused me a headache for 4 weeks along with a broken cable on the TPS.
Decided to change throttle body with sensors in place as I can’t seem to separate these sensors from the body ???
The
Hi there
Thanks for info
The
there's pushed in. But nothing to pull on.
if you put a Hose clamp around them you can lever them out with a screwdriver.
Mark everything carefully First. But from memory they only fit one way but could be wrong.
be careful diagnosing TPS errors
a miss match between the throttle pedal and throttle position sensor can throw the same code
we seen a couple of throttle pedals fixed by compressed air along with a couple changed recently. And I have seen the connector corroded and gone green
