Hi guys!
I was in the process of swapping a T-Jet into my Punto MK2. Got the engine shipped to me from a scrapyard, and the engine arrived in good looking condition (externally).
Now, the engine was left on a workbench in my garage for a few months (5 months, maybe?) while I took care of everything I needed to make it fit. Upon observing my already swapped 1.2 16V I figured everything was pretty much the same on the gearbox side of the engine, so added 8V coils (the car was originally an 8V) and modified a flywheel from a 1.2 16V to fit the T-Jet, by slightly enlarging the bolt holes as the T-Jet uses M9 bolts.
Afterwards the flywheel was fitted to the engine (at this point I cannot recall for the life of me if the crankshaft turned or not... But I'm pretty sure that it didn't. The reason I say this is I applied a lot of force to the flywheel bolts while torquing them and that would have made it turn) and then the Punto standard 5 speed was mated to the block.
Now, the engine won't start. I tried engaging 5th speed and rocking the car back and forth to see if the engine was seized or mechanically stuck, but no movement whatsoever. I took the plugs out while doing this, and took a peek inside the combustion chambers. No aparent signs of water getting in, which is a good thing, but the engine is not moving.
So... Assuming the engine is seized... What should I do now? Is there any way I can make it unstuck without having to open the damn thing?
Pics for reference:
Pics for reference:
