Technical How to remove the side indicator lenses?
keiron99
The front side indicators (is that what they call "repeaters"?) have got quite a bit of muck behind them and I'd like to remove them and give them a scrub.
I'm sure they are just push ins, but does anyone know how to remove them without breaking any tabs? Would I need to remove the wheel arch liner or could I carefully pry them out with a flat blade?
I tried with an old credit card, pushing from all angles, but couldn't get it to budge at all.
Can't remember if i had to use a flathead screwdriver with an insulated shaft so as not to scratch the paintwork.
The paintless dent guy ( Mike, Dent Reverse - Cannock) managed to remove the arch liner without taking the wheel off! I guess that's experience : )
You don't need to take the arch liner off. I've taken the lens off without taking the arch liner off.
When all else fails ... "read the manual".......LOL
_______________________________________________________________________________________
" To change the bulb, proceed as follows:
lever the lens off, by initially applying force from the front towards the back (1 -fig. 112);
then lever in the opposite direction, by applying force from the back part (2 - fig.112) and remove unit B;
turn the bulb holder anticlockwise, extract the clipped bulb and replace;
refit the bulb holder in the lens, then position unit B, ensuring that the fastening clip clicks into place. "
That's exactly as I have been doing it, but still cannot get them to budge! I guess I'm just not courageous enough to push too hard for fear of breaking them.
