General How to remove the inner rear door lever
plato0234
Hi I have a Doblo 56 plate and am trying to remove the rear door lever... is there a tool to use because I presume there is a circlip behind it although I can't see it !
Push the door panel back hard look in the gap there will be a wire clip on the handle either a thin screw driver or a piece of stiff wire bent into a very short hook.
Pull it up the clip will FLY out !! a cloth over it will stop it going to far.
To re fit put the clip back on the handle place handle on shaft & a sharp bang will re fit,
The retaining clip is the thing you are looking to remove
images
Thanks ...top man !
The small circular casting attached at the rear of the key lock assembly has broken off . Does anyone have an idea to repair it ?
thanks
Has it broken or is it held on by a screw
Hi , I just used my camera on it ...it looks like it should be held on by a screw ...which must have fallen off ...i'm guessing it's an M4 screw with a hex head so I can put an allen key in the space ...can anyone confirm this ? Thanks
