Technical how to remove front speaker?
Nobrain
Timisoara
Right front speaker started to do some buzzing.
Can i remove the speaker by pulling or i have to dismantle the inner part of the door.
Do you mean the small tweeter in the mirror panel? Tweeters buzz and Mids fart.
If so you have to prise the top outwards. This will release a clip then push upwards to disengage the stabilising stalks.
Basically when it's stuck at the top you just need to give it a nudge.
Tap it on the bottom with the cover in the natural position, close to assembly point.
Window being down is an advantage. All it needs is a little bit of pressure. :)
