General How to Flush out, Radiator ?
BravoCity
I have a Fiat Bravo 1.9D M-Jet, How do I flush out my OLD Radiator Coolant to top it up with New Pink Coolant :D
Usually you disconnect the bottom radiator hose. But make sure you know where the bleed nipples are before you do that, or you'll get air locks when you re-fill...
You don't disconnect any hose.
There is a drain valve on the bottom and a bleed valve on top of the radiator for that job.
