How do you know if..
luvduvs
SNAP!
Sydney
your computer is on its way out?
Someone said there's a tool within Windows that tells you how your hardware is doing with ticks & crosses - anyone know where/how to use this?
if it's about to break
:yeahthat:
My colleague's HDD crapped itself, and the tech said if she ran the tool and spotted the problem beforehand, she could have backed up everything instead of losing everything now.
a tool within Windows that tells you how your hardware is doing?
man you're really gullible, they must love winding you up! :p
you have to think about how software can make an assessment, it has to be given data, and the only data that can be obtained is temperature, rpm, disc state (partition validity) and read/write success.
lets consider which type of failures that info could provide a warning for:
logical corruption
corruption will occur suddenly at a certain time for no physical reason, it is impossible to predict when this will happen, even a second before it does. once it happens you lose the partition and the disc is unformatted as far as anything is concerned.
elec failure
usually controller board failure caused by a voltage spike. this is undetectable by software because there is nothing there before the failure and the failure happens suddently due to external factors that can also not be predicted, although they can be avoided.
mech failure
usually when your drive starts to tick, this can be predicted before data is lost if read/write errors begin to occur, often you find failure starts as an intermittent fault. if software was able to access a log of read/write failures then this would be possible, it currently isnt but in theory the mechanisms are there to do this. you could also have software to notify you in real time when a read/write error occurs, but windows does that for you already so why bother?
firmware failure
the firmware can be corrupted or lost, usually when this happens the drive spins but wont recognise, or it recognises then stalls. there is no way to predict this and you get no warning. data can be recovered when this happens so its no biggy, other than the inconveniece of recovering data and writing it to a new drive.
out of the typical hardware failures only one type could be predicted by software, and that is the easiest type to predict without software because you start to get read/write errors, you dont need some software to tell you that.
so in summary, common sense tells you a piece of software can neither predict nor diagnose the vast majority of hard disc failures. it is not possible unless you can predict the future.
I'm not - the tech showed my colleague how to do it - I'll ask him to show me next week.
But I do agree - doesn't hurt to backup regularly.
When you get time could you pop down the shop and get me a "long weight" and some "tartan paint"
i didnt think event viewer could help you decide "how your hardware is doing" or "if it's about to break". i've always used it after a system failure to see what happened (much better than asking the user what happened lol) but i've never seen it diagnose anything hardware related or provide any info that was 'before the fact', if it can do it i'll be over the moon.
Some servers can give timeout errors from a SCSI controller suggesting a disc has failed or unexpected memory errors which can mean anything from faulty memory chips to problems with riser cards :rolleyes:
As you say though - normally the most you will get is "Shutdown at xx:xx was unexpected"
Event Viewer Diagnosed my Failing Hard Drive before it failed. If it had like warned me I would have had more time but I had to check it first.
My Hdisk was failing for months before it actually became noticable to me by the constant crashes and resets.
Event Viewer knew.... it just didn't tell me.
The message was something like, blah blah error on Disk 1, Back up and Replace immediately!
But it never told me :(
