Is there an easy way / method of bleeding the coolant system on a 1.6? I have been trying for the last six weekends to do this, I got it right once (don't know how I did this) but I had no anti freeze in it so I took the top hose off to let some water out topped up with anti freeze trapped more air. I have bled it and filled the system from all sorts of access points. I have used the bleed screw on rad, the heater pipe bleed screw and the water sensor in the thermostat. Any advice would be appreciated I'm trying the method "joipalli" advised me on tommorow.
