Hi folks. I know that there are a bunch of threads with this problem but i cannot get around it.
I have te starting problem when hot, starter motor turns but no ignition.
I went to the tester, it showed only the crank sensor error, changed that, did a reset on the ECU but still the same.
It's a little weird cause when cold starts, revs max up to 1500, then works fine no fuel problems, then if i turn off the motor if i start it right up it will start no problem, but if i let it longer then 5 min then it starts at the first turn but gets up to 1000 revs and then drops until the engine cut's off. After i turn again the key, starter motor turns but engine won't fire up unless i keep it cranked.:bang:
Changed the crank sensor, cleaned the stepper motor, fuel it's getting in the injector rail, don't have a clue anymore.
